Shenzhen B&T Technology Co., Ltd ( Short for B&T, NEEQ: 430597 ), Founded in 2003, B&T embedded modules add Wi-Fi, Bluetooth, LoRaWAN, LoRa, GPS, NB-IoT, 2.4G or GPRS wireless IoT connectivity to any device. Provide customers with a full range of RF solution modules, antennas, wireless performance testing and solutions.
Maximum transmit power is optional (see the design guide below for configurationmethod)
①Default configuration: The internal PA uses a 3.3V power supply voltage. In this state, the maximum Tx Power can reach +29dBm, and the operating current is 750mA;
②Optional configuration: The internal PA uses a 5V power supply voltage. In this state, the maximum Tx Power can reach +31dBm, and the operating current is 1A;
High sensitivity: as low as -137dBm@SF10 125KHz
Extremely small size 17*16*3.2(±0.2)MM, double row stamp hole patch package
Support spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11
It has low power consumption in receiving state, and the minimum receiving current is16mA
The module uses SPI interface, half-duplex communication, CRC, and up to 256 bytes of data packet engine
Support a variety of antenna installation methods, compatible with half-hole pad/through-hole pad/IPEX connector
