• Home
  • About Us
    Company Profile Corporate Culture Honorary Award
    Our Partners
  • Product
    PCBA IoT Module Antenna
    FRI-LAB
  • Solution
    Wi-Fi Solution Radar Solution LoRa Solution
    Bluetooth Solution GPS Solution Offline Voice Solution
    NB-IoT Solution
  • Document
  • News
    Shenzhen B&T Technology Co., Ltd ( Short for B&T, NEEQ: 430597 ), Founded in 2003, B&T embedded modules add Wi-Fi, Bluetooth, LoRaWAN, LoRa, GPS, NB-IoT, 2.4G or GPRS wireless IoT connectivity to any device. Provide customers with a full range of RF solution modules, antennas, wireless performance testing and solutions.
    Latest News Company News Industry News
  • Sample Buy
  • Contact Us
  • TYPE-R
Antenna
Chat Now! Chat Now!
  • PCBA
  • IoT Module
  • Antenna
  • FRI-LAB
Frequency Range
All
433MHz470-486MHz868MHz915MHz900/1800MHz2.4G2.4G/5.8G3G4G5.8GGPSGPS+BD3.5~6.5GHz
External Antenna
All
Sucker AntennaRod AntennaPepper antennaAngular antennaPaddle AntennaBread AntennaGPS Antenna
Built-in Antenna
All
FPC AntennaPCB AntennaShrapnel AntennaCopper Tube AntennaSpring AntennaCeramic Antenna
Accessories
All
RF CableConnectorTerminalThimble
  • 2.4G external black long foldable antenna
    The rod-shaped antenna has better conductivity, does not need to be debugged, is easy to replace, and has high antenna gain. It is suitable for larger terminal devices with no space limitation.
    Learn More
  • 433-453MHz built-in antenna (spring ¢ 0.8 × OD5.5 × N19.75 × L33.8)-A4
    The cost of the spring antenna is relatively low,small size, easy to install, good antenna standing wave ratio performance, and also has good anti-vibration and anti-aging capabilities. The wireless module can be used in conjunction with it to
    Learn More
  • 2.4G built-in antenna (shrapnel: 35.4 × 31.7 × 8.8) -black 1.13 wire-terminal, see wire length 250mm (original IPEX)
    The shrapnel antenna has good conductivity, and it has a long service life and a high shielding effect.
    Learn More
  • 2.4G built-in antenna (PCB 60 × 18 × 1)-black 1.13 wire-end stripping: 2-2-1, L = 40mm-A1
    PCB antennas are widely used in single-frequency module circuit boards such as Bluetooth modules, WIFI modules, and ZIGBEE modules.
    Learn More
  • 2.4G built-in antenna (PCB 40 × 7 × 1) -gray 1.13 wire-terminal-1
    PCB antennas are widely used in single-frequency module circuit boards such as Bluetooth modules, Wi-Fi modules, and Zigbbee modules.
    Learn More
  • 2.4 / 5.8G built-in antenna (FPC 29 × 18)-gray 1.13 wire-terminal, L = 48mm-A1
    The FPC antenna is suitable for smart hardware products with complex frequency bands. It has stronger performance, higher integration, and lower cost.
    Learn More
  • 2.4G built-in antenna (FPC 45.3 × 7.2)-gray 1.13 line-IPEX-1
    Learn More
  • RF Radio Frequency Cable Double MCX-J Elbow-1
    RF cable (RF jumper) RF cable assembly is a combination of RF coaxial connector and flexible cable or semi-rigid, semi-flexible cable, widely used in microwave equipment and
    Learn More
<< 1234 >>
  • About Us
    Company ProfileCorporate Culture Honorary Award Our Partners
  • Product
    PCBAIoT ModuleAntenna FRI-LAB
  • Solution
    Wi-Fi Solution Radar Solution LoRa Solution Bluetooth Solution GPS Solution Offline Voice Solution NB-IoT Solution
  • Document
    Document
  • News
    Latest NewsCompany NewsIndustry News
  • Sample Buy
    Sample Buy
Contact Us
+86-755-29162996 ; +86-15989589908(skype)
Address: Room408-410, Building C, Huafeng Intelligence Innovation Port, Gushu, Xixiang, Baoan District, Shenzhen,518126 ,China
Copyright © 2020 Ai-Thinker Co., Ltd. All Rights Reserved
Terms of Use | Privacy Policy
